Wonderware Question Opening a Excel Sheet
randy741985
Oct 2006
US
154
Wonderware Question Opening a Excel Sheet on the network server from all wonderware stations on the same Network.
I want to create a button that will open a excel sheet that is located on the LAN Server, its on the same network so thats not a issue.
Thanks in Advance
your best bet is to map the directory as a drive on each machine.
the script from there will be startapp "z:\filename.xlsx" for example.
This may work but I didnt want to do like that, I may try just using a path, Didnt want to keep up with mapping a drive, because I have to replace a machine now and again.
Thanks,
I have to work on a Wonderware HMI and have very little experience with it. The basic idea is to copy an old project, make a few edits, and load...
4,938
Im using Wonderware Intouch machine edition v8.0. Question: How does the Math Worksheet/Task scripting work? I have the following expression...
2,261
Hello all, I'm using WonderWare Intouch at my factory for the HMI. Here is what I'm trying to accomplish: Save data values (27 of them) into one...
21
7,579
Hi Guy 1. Please how can I create a shutdown button on the intouch? 2. Also how can I configure graphical Trend for 9 different values/tags in it?
2,791
Is Inbatch basically programmed similar to a PLC, it then reads/writes to a dumbed down PLC, which then performs the outputs? I'm having trouble...
3,248
