Wonderware question
bill4261
Jan 2005
mid-west
99
I used a CreateFileNameFromDate script in an application several years ago. And can't remember where I found it. It's not in the standard selection list. I know it wasn't a third party script. Is anyone fimilar with this?
There is usually a section of their website that is for support scripts. That is where a lot of useful functions (dlls that you may have to add to the WW directory) or quickscript examples.
Darren
I think what you are looking for is the "FactorySuite Script Function Library".
It has the following functions:
The FactorySuite Technical Support script function library contains the following script functions for Wonderware® InTouch™ 6.0 and later for Windows NT 4.0. All script functions listed below are fully documented in the Descriptions section later in this topic:
Measurement Units Conversion:Area and Volume Calculations:StdFromMetLinear()GeoArea()MetFromStdLinear()GeoEqualSideArea()StdFromMetFluid()GeoVolume()MetFromStdFluid()StdFromMetWeight()MetFromStdWeight()Writing to a .INI File:Writing to the Spcex.ini FileINIWriteString()SPCEXSetStartDate()INIWriteInteger()SPCEXSetStartTime()INIReadInteger()SPCEXSetEndDate()INIReadString()SPCEXSetEndTime()SPCEXSetProduct()SPCEXSetDataset()SPCEXSetOutputFile()Tag Support Functions:File Name Creation:TagExists() CreateFilenameFromDate() GetDiscOnMsg() GetDiscOffMsg() SetTagEU()Miscellaneous Script Functions:WWShutDownWinNT40()WWShutDownWin95() SystemIsNT()WWBeep32()WWCntx32()
If you still have access to the machine with the function you want just copy to following files to your other machine: "WWTech32.DLL" and "Wwtech32.WDF". They should be located in your InTouch installation directory.
Darren
I have to work on a Wonderware HMI and have very little experience with it. The basic idea is to copy an old project, make a few edits, and load...
4,960
Im using Wonderware Intouch machine edition v8.0. Question: How does the Math Worksheet/Task scripting work? I have the following expression...
2,262
Hello all, I'm using WonderWare Intouch at my factory for the HMI. Here is what I'm trying to accomplish: Save data values (27 of them) into one...
21
7,587
Hi Guy 1. Please how can I create a shutdown button on the intouch? 2. Also how can I configure graphical Trend for 9 different values/tags in it?
2,796
Is Inbatch basically programmed similar to a PLC, it then reads/writes to a dumbed down PLC, which then performs the outputs? I'm having trouble...
3,250
