Wonderware Robotic arm animation
SLC500
Dec 2008
Sudbury
27
I am trying to recreate a graphic for a robotic arm and I am not having any luck.
I would like to be able to have the graphic move together as one but be able to move each section of the arms independatly.
I have seen it done using Factorytalk a few years back and I am trying to do the same in wonderware.
The problem I am having is being able to link the end of one moving arm to the next section(s). I have tried making them symbols and cells but the second section will not move with the first arm and still rotate indipendantly from the first.
Thank you for any input.
Pffieuw
Pffieuw,
Are you doing this in the Archestra IDE ?
off the top of my head:
Think of creating a long rectangle (to represent an arm), then at one end attach a circle (to represent the joint, like an elbow), then make a symbol/cell out of them. Use a script to rotate the circle. When the circle turns, the "arm" will move up and down.
174
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
116
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
204
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
197
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
175
