Wonderware Supertag member Cant See/Delete
deljvk
Mar 2015
angeles
21
I'm using Wondeware Intouch 9.5 and I got an issue on it. It has several supertags and some already had
exceeded the allowable 64 members. Well according to my reading, these excess tags must have done through
DBLoad, is this true? Now, it seems that there is no way for me to pull up and edit properties of these
members, they don't appear on the tagname dictionary, only 64 members appear. If I do DBload for these
supertag members, I was prompted "64 members supertag limit exceeded, please cancel or create a new
supertag" it wont let me. Is there a work around for this? Is this some kind of a corrupted application?
In addition, I got a job to delete some supertags and some members had left untouch, I can see these members
when I DBdump, the supertag itself no longer appears on the dictionary. Any idea? <btw, I'm referring to the same application above>
Just one more question, the IOGetNode("AccessName"), would this also works on secondary source? I'm actually
working on redundancy servers.
Thanks, and I appreciate for your inputs.
Vince :)
Vince :)
hello,
I have a same problem, can you help me.
thanks.
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
149
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
102
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
183
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
179
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
162
