Wonderware unbound grid required
Greg Fowlds
Apr 2004
Currently, Waiheke Island, NZ
123
What ActiveX grids are there that will function in Wonderware other than wwGenericDataGrid.
Trying to find a simple unbound grid.
Wonderware v10.1, Win 7.
Have tried FlexCell,and iGrid.
Both have issues with format of methods etc that are not compatible with WW and generate errors on validate.
One way is to write a wrapper using MsFlexgrid or similar so that Intouch can access the properties and methods in the correct format in script.
Any one know of such an Activex MsFlexgrid that has been wrapped for intouch?
Will probably have to roll my own,🔨.
Customer wants to continue using original Wonderware and it is missing any kind of grid other than the wwGenericGrid which is only bound to a database.
Hi guys, I have experience with PLC to Excel etc...just starting on using intouch scada screens. I have an Excel sheet that uses mainly...
159
Hello everyone, Recently, my Archestra IDE shut down while I was editing. After restarting the IDE, I noticed warning symbols under my opened...
106
Good morning all. I'm working on a rehab where they had a standalone InTouch 2014 HMI that they called a SCADA, but it's really basic stuff. The...
190
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
184
Hola chicos. Tengo un problema con el driver de comucicacion dasabcip 5, y un plc controllogix v34, ya realice la comunicacion pero en ciertos...
169
