Wonderware WindowMaker fault
MGuenette
Jan 2007
Montreal
134
I'm just trying to open my application with window maker and I always have a fault. I reinstalled Intouch with the update patch and no success.
the fault is :
The application cannot be edited. Process "" on computer "" is editing this application.
Anyone has any idea?
Martin.
Windowmaker uses that file to prevent the application from being changed by anyone else. It creates that file when it opens and deletes it when it closes. If Windowmaker doesn't close correctly (crash) that file might not get deleted. I found out about it from WW Tech Support.
New Improved Fault: Can now also be file location
I had this error message, but no appedit.lok file.
I relocated my file from
C:\Documents and Settings\myxx.namex\My Documents\Client Jobs\A11111 - Client Name Location\Working\Wonderware 2008-09-04\Wyee.WW
to
C:\Documents and Settings\myxx.namex\My Documents\My InTouch Applications\Wyee.WW
And the problem went away. I don't know if it was the length of the path, or the hyphens in it.
This post applies to Wonderware 10.0
MGuenette said:
the fault is :
Martin.
This happens if you copy a running app. from a pc and try to edit it on another pc.
thanks
you are right, i had the next message when opened windowsmaker
"The same application is being edited in other session, cannot edit this application" delete this file and it works fine
many thanks
Thanks for these posts. Just had this same situation. Deleting the appedit.lok file didn't work, then removed folders with dashes, and now I can open it in WindowMaker. Had dashes for the date, and a rather long path. I'm using V10.1. :site:
to
I recently had a similar issue but there was no appedit.lok file.
Turned out that the folder was read only, copying to a non read only directory solved it.
Hi, I am upgrading a Wonderware SCADA form version 9.5 to version 23. I am able to migrate all the graphic, but when to activate the runtime this...
434
I am unable to open and edit a project with windowmaker. I am able to open the project with windowviewer and can operate through the scada with...
2,743
Hi All, When I try and run WindowMaker I get the follwoing errors: 1. Corrupted Database 2. Read Error 3. DB cannot be loaded. Are database files...
17,361
I was doing some changes to an InTouch project when I realized I had done a mistake that I couldn't undo. So I restore a backup I had of my...
9,683
We are in the process of testing Wonderware 10.3 under Windows-7 64-bit and one thing we have noticed is that WindowMaker will not run without...
11,179
