WR2 compensation
JamesWSY
Jul 2005
Jakarta
81
I want to calculate wr2 compensation on winder application (inertia compensation during accel and decel). How to calculate it? Any formula?
Thank you for suggestion.
James
Well, WR² varies as the square of the speed ratio. So, if you know the WR² of the roller and you know the gear ratio you can calculate the WR² seen by the motor:
WR² motor = WR² load x (rpm load ÷ rpm motor)²
where WR² is in l-ft²
If you want to calculate the WR² itself, I direct you to most any mechanical engineering handbook, such as Machinery's Handbook, Mark's Handbook for Mechanical Engineers, etc. Many VFD applications handbooks have formulas for simple shapes such as cylinders, discks, etc. I know the Cutler Hammer Adjsutable Frequency Drive Application Guide does, and so does the corresponding Allen Bradley guide. These are available online.
For privacy, I am posting under a name I don't normally use. It is a name I actually created several years ago when I was pretty frustrated with...
19
6,491
Hello all, I have some doubts regarding the sizing of the protection and cables for a reactive compensation. The reactive I have to compense is...
1,005
Good day folks, When doing pressure compensation on a flowmeter to get mass flow. Should the flowmeter read the pressure input at gauge or...
18
2,971
OK so this is off topic but I didn't know a better place to ask. I also signed up with an alternate ID because I’m trying to remain anonymous to...
23
5,801
This is a little OT but I believe this is the best place to ask this question. I have been in system integration for over 16 years, I spent 10...
24
5,436
