Write value from one tag to another tag in WinCC
shailesh_vb
Jun 2013
Pune
43
Hello Everyone,
Can somebody tell me how I can move a internal value ( word, int, float etc) to a external tag in C script or VBS or another options.
I need something like below:
Tag1 = Tag2;
Please help.
Thank you in advance.
Regards,
Shailesh
Been some time but I think you can use smarttag
SmartTags("HMI_Tag_1") = 1
or
HMIRuntime.Tags("Tagname_1").write = 6
For WinCC scada and C the following syntax applies
GetTagBit("TagName");//Return-Type: BOOL
GetTagByte("TagName");//Return-Type: BYTE
GetTagChar("TagName");//Return-Type: char*
GetTagDouble("TagName");//Return-Type: double
GetTagDWord("TagName");//Return-Type: DWORD
GetTagFloat("TagName");//Return-Type: float
GetTagRaw("TagName",pValue,size);//Return-Type: BOOL
GetTagSByte("TagName");//Return-Type: char
GetTagSDWord("TagName");//Return-Type: long int
GetTagSWord("TagName");//Return-Type: short int
GetTagValue(lpdmVarKey,lpdmresult,lpdmError);//Return-Type BOOL
GetTagWord("TagName");//Return-Type: WORD
SetTagBit ("TagName", short int value);
SetTagByte ("TagName", BYTE value);
SetTagChar ("TagName", LPSTR value);
SetTagDouble ("TagName", double value);
SetTagDWord ("TagName", DWORD value);
SetTagFloat ("TagName", float value);
SetTagRaw ("TagName", BYTE* pValue, DWORD size);
SetTagSByte ("TagName", char value);
SetTagSDWord ("TagName", long int value);
SetTagSWord ("TagName", short int value);
SetTagValue (LPDM_VARKEY lpdmVarKey, LPVARIANT lpdmValue, PDWORD dwState, LPCMN_ERROR lpdmError);
SetTagWord ("TagName", WORD value);
Hi, first sorry my english. I need help. Im using RSView32 7.40 I want to write value to a tag from Visual Basic. i calcualted something in...
1,361
I need to do a activity history of all panelview plus users (for Controllogix processor).Only I need to know who's logged and put a value inside a...
2,169
Hello All, Can Someone tell me the correct program syntax (Crimson 3.0) to write a value to an Internal scrren tag. ie. 1. User Presses a...
2,122
hi i am using rs view32 in which i want to write value in tag through vb. for example i have a tag higest_value as a integer which is decleared in...
21
30,350
I've devoleped a VB application for retrieve data from an Access database and now I wont write this values to some tag into my RSView studio stand...
3,943
