Peter Nachtwey
Interesting.
Thomas_v2, you must work for Siemens then.
I tried compiling your example. I don't support user functions yet. I don't to automatic conversion because that is not in the specifications and for some reason I couldn't get my VAR_TEMP..END_VAR to work but with a few modifications to your code I was able to generate this:
About the optimization. Like I said I haven't thought about it too much but I have thought about cases like
C:=3+A+B+4;
The 3 and 4 should be combined but they are at different points in the tree.
This is the part I haven't got figured out yet.
I bought the dragon book a long time ago. It cost $19.95 and is the second printing from 1978. As I said before, I always wanted to write a compiler. I think I have waited long enough. Most is now obsolete unless one is writing the Flex and Bison code too.
Code:
PROGRAM TEST
VAR_TEMP
Y,A,B,C,D,E,F,T: REAL;
I,J : INT;
END_VAR
I := 123;
a := 5.6;
b := 21;
y:= ( a + INT_TO_REAL(i) ) * b;
END_PROGRAM
Generating Code
TEST: LD ANY_INT# 123
ST INT# I ; offset=32
LD ANY_REAL# 5.600000
ST REAL# A ; offset=4
LD ANY_INT# 21
ST REAL# B ; offset=8
LD REAL# A ; offset=4
LD INT# I ; offset=32
INT_TO_REAL
ADD ; REAL
LD REAL# B ; offset=8
MUL ; REAL
ST REAL# Y ; offset=0
RET ; END_PROGRAM
PROGRAM #OPR = 3
LABEL NULL# TEST
VAR_DECLARATIONS #OPR = 2
INT# 0
LIST #OPR = 2
VAR1_INIT_DECL #OPR = 2
VAR1_LIST #OPR = 2
VAR1_LIST #OPR = 2
VAR1_LIST #OPR = 2
VAR1_LIST #OPR = 2
VAR1_LIST #OPR = 2
VAR1_LIST #OPR = 2
VAR1_LIST #OPR = 2
VAR REAL# Y
VAR REAL# A
VAR REAL# B
VAR REAL# C
VAR REAL# D
VAR REAL# E
VAR REAL# F
VAR REAL# T
TYPE = REAL
VAR1_LIST #OPR = 2
VAR INT# I
VAR INT# J
TYPE = INT
STATEMENT_LIST #OPR = 2
ASSIGN #OPR = 2
VAR INT# I
ANY_INT# 123
ASSIGN #OPR = 2
VAR REAL# A
ANY_REAL# 5.600000
ASSIGN #OPR = 2
VAR REAL# B
ANY_INT# 21
ASSIGN #OPR = 2
VAR REAL# Y
'*' #OPR = 2
'+' #OPR = 2
VAR REAL# A
FUNCTION #OPR = 2
INT_TO_REAL FC INT_TO_REAL
VAR INT# I
VAR REAL# B
You can see I have a parse tree too. Right now I think of the pseudo assembly as the intermediate code. However, much of the pseudo assembly will translate instruction for instruction. The micro controller I am using only accesses memory from load and store instructions. Other instructions like + and * only work on registers.My parser builds the parse tree.
Those are done by the recursive subroutines.Then I've got different visitors which walk through the parse tree an do things
I haven't worked on that too hard. I will do so later and I think it will be the fun part. My target micro controller has 32 registers. It is a freescale micro controller. I can easily map 8 most recently used variables into these registers and like I said, the micro controller has a pretty big cache. This gives me a huge advantage in the ability to optimize over writing code for the S7 which has few registers and each is special.like code optimization like constant folding and the code generation.
C:=3+A+B+4;
