Writing a VBS value into a WINCC tag
teckhno2002
Nov 2005
Craiova
35
I have this situation in a Global Script (Action)
v(1) is associated to “tag1” from WINCC
v(2) is associated to “tag2” from WINCC
v(3) is associated to “tag3” from WINCC
dim v(3), t(3), i,
For i= 1 to 3
If t(i) <256 Then
v(i) = 1 ‘v(i) must be writen into the appropiate WINCC tag .That means
‘v(1) to “tag1”, v(2) to “tag2”, v(3) to “tag3”.
Else
v(i)=0
End if
Next
[FONT=&quot]
How can I send the element
[/FONT][FONT=&quot]of the matrix [/FONT][FONT=&quot]v(i) to the WINCC tag in this specific case?
[/FONT]
Found the answer
Option Explicit
Function action
Dim v(3),t(3),i
Set v(1) = HMIRuntime.Tags("v1")
Set v(2) = HMIRuntime.Tags("v2")
Set v(3) = HMIRuntime.Tags("v3")
t(1)=HMIRuntime.Tags("t1").read
t(2)=HMIRuntime.Tags("t2").read
t(3)=HMIRuntime.Tags("t3").read
For i = 1 To 3
If t(i)<100 Then
v(i).Value = 1
v(i).Write
Else
v(i).Value = 0
v(i).Write
End if
Next
End Function
Can you please help me 'dynamic filling' properties in wincc?
How to change the foreground and background colors of polygon using dynamic filling?
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
275
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
104
Hello All: I have a Windows 10 PC running a FTView ME Station 10.00. I have a .mer file version 6.00. It has been running well on it for a long...
178
My R55 Ingersollrand is tripping on motor overload and im falling to see the trip history it is writing Acquarring texts
138
Hi. Not the fist time I'm saying this but just to give a background. 95% of my PLC programming has used Schneider over the last 10 years on...
66
5,017
