Hello all, Can I request help on writing LD on this forum. I have a three way switch that's going to the plc to run my motor cw, ccw, and reverse cycling. The reverse cycling will need some type of timing.
(cw time)----(brake time)----(ccw time)----(brake time)----repeat
The contacts of the switch are cw to I0001, ccw is open, and the reverse cycling is to my I0002. I'm using a GE Versamax Micro with Versapro. I have the manual GFK-1645C. But not writing before and just learning about PLC's has me at a disadvantage
I'm sorry if this is not clear. I've never programmed before and I'm quite overwhelmed. Your help will be appreciated.
