writing to Quantum PLC input table?
archer1
Aug 2006
Waterloo
Is there a way to write to the Quantum PLC input table so that I can simulate 1XXXX data values?
We use a patch file [1X3X instruction] written by someone at Gould for old Modicon PLCs which does this. But I can't find anything similar for the newer Quantum PLCs.
I just asked about the 1X3X instruction a short time ago!
In Concept, unless the 1X3X instruction will work in the ladder section, you probably cannot simulate in this way.
When I used to use Concept, I would do it this way.
1, Do not use direct addresses, only declare variables with addresses.
2, When ready to test, export the variable table to a text file.
3, Strip out the addresses (this is easy in Excel), make sure you have 2 saved copies, one with addresses and one without.
4, re-import the variable table without addresses
5, simulate as much as you like
6, when you are ready, re-import the file with addresses.
To be more specific, I want to use I/O emulation software (PICS) running on a PC and talking to the PLC using a Modbus OPC server. I'm not sure your suggestion still applies then, does it?
Thanks for your help.
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
280
Hello all, I'm currently working on a servo motor linear positioning system (ball screw). I'm all set up regarding communication between my HMI...
107
Hello All: I have a Windows 10 PC running a FTView ME Station 10.00. I have a .mer file version 6.00. It has been running well on it for a long...
178
My R55 Ingersollrand is tripping on motor overload and im falling to see the trip history it is writing Acquarring texts
138
Hi. Not the fist time I'm saying this but just to give a background. 95% of my PLC programming has used Schneider over the last 10 years on...
66
5,029
