WTB: Proximity switch protection box
jdbrandt
Oct 2002
Pennsylvania
1,203
I have a customer need for what he is calling a proxmity
switch protection box.
He has described it as a box that the proximity switch (30mm)
sticks out from, and also has a 3/4" conduit fitting on the
other end.
Now, this proximity switch is in an outdoor, dust and heat
situation, but I think his real intent is to have a nice place
for the wires to be connected to the wires coming thru the
conduit.
Does anyone know a source for something like this, or am I
gonna have to build these (I need 10).
Thanks, in advance.
I would tend to use a sensor with cable attached to it. They can be bought from any supplier.
When dust is a problem be sure to use explosion proof material and plc.
If very hot please be sure the sensor can work on these high temps.
for connection box i use aluminium boxes with glands only on bottom.
when no room i use a piece of shrinktube filled with some glue, available from 3M. works very fine and everywhere.
i am in coldstores so my problem is water, and ice.
I don't know the size of the proximity switch you are talking about but I worked for a brick company, where dust, heat and possibilty of falling brick were some of the issues to deal with. I have used outdoor receptacle boxes (Dual gang if need be).
Thanks to all...
but,
1.) The end user will not accept Armor Guard proxes.
2.) A conduit adapter does not allow for adjustment.
so...
I've decided to use an Allen Bradley 871 accessory that
allows for 'quick adjustment', and will mount in a little
NEMA 4 box (traditional wall boxes are not NEMA rated, for
some reason), and then mount a 3/4" hub in the box, as
a do-it-yourself type deal.
Thanks for the input.
I have a retrofit project, and need a signal conditioner for one of the old-style variable reluctance/inductance sensors that were used (by...
3,022
Anyone knows where I can get a new/used Siemens OP37? It has been discontinued by Siemens several years ago. 6AV3637-1LL00-XXXX...
2,743
As of a year ago, Allen Bradley has discontinued selling the conversion software so we're looking for a copy to purchase. We got a quote from A-B...
2,905
I'm looking for a panel-mounted unit that has a small amount of I/O, keypad or touch interface for operator interaction, comm port for...
1,589
Hi all, First, thank you for reading the thread. So I had a task as the following: An up-counter must be programmed as part of a batch-counting...
300
