WTB: Siemens OP37
yxannes
Aug 2005
Singapore
38
Anyone knows where I can get a new/used Siemens OP37? It has been discontinued by Siemens several years ago.
6AV3637-1LL00-XXXX
6AV3637-1ML00-XXXX
I am having trouble finding anyone that has it that is willing to sell. Any help will be appreciated.
If you have a broken OP37, then Siemens can repair it for you (dont expect it to be cheap).
You can try ebay.de, they have a lot of Siemens stuff, but I am afraid that the OP37 wasnt very common so the chances are slim.
If you have the original program, then a better solution would be to convert it to something more recent.
The current model that matches the OP37 best is OP270-10. It can be programmed with Protool or Win CC Flex.
There is a new version on the way allready (OP277), and that one will only be possible to program via Win CC Flex.
Second hand op37
I have 2 units available.
I have a retrofit project, and need a signal conditioner for one of the old-style variable reluctance/inductance sensors that were used (by...
3,022
As of a year ago, Allen Bradley has discontinued selling the conversion software so we're looking for a copy to purchase. We got a quote from A-B...
2,905
I'm looking for a panel-mounted unit that has a small amount of I/O, keypad or touch interface for operator interaction, comm port for...
1,589
I have a customer need for what he is calling a proxmity switch protection box. He has described it as a box that the proximity switch (30mm)...
7,041
Hello everyone, I've had this issue for the last 2 days where I try to assign the profisafe address to an IO block (6ES7 146-6FF00-0AB0) but when...
112
