[WW Intouch] Trend Problem
had-z
Dec 2013
Punta Arenas
I'm having some troubles with Intouch trends, some trends are showing constant, the tag is updating fine, the trend of the others tags of the access name are showing ok
Hope someone have a solution for this, the problem is recurring for almost a year.
-Intouch 2012 R2, W2008 Server R2
Regards.
Thanks for the reply, but that's not the problem, the trends displays, but without variations (the tag is updated correctly)
What is the logging deadband for the tag? Set it to zero which will log every time the value changes, restart Intouch and then check your trend again. If that fixes it then set the deadband to a suitable number.
This is configured in the tagname dictionary
Hi,friends i tried to make historical trend in intouch 10.i have assign 2 memory integer tags as pen, In historical trend i use black as border...
9,593
Hi !!! I'm getting rid of the old IT10.6 that was working on Workstation. I'm using servers with ThinClient (NAD enable). If I run the app, now...
1,393
Is there anybody know why Histrend do not display the trend (i had sticked LOG DATA )? The current value of sensor is still display, if you've got...
1,093
Hello, I am working on a SCADA system using Wonderware Intouch 2014 R2 and have a small glitch with the historical trend feature. Every time I...
2,865
Hi, I've got I think a simple problem but I can't find the solution. In Wonderware Trend my server is disabled/not active but I can log in to it...
1,280
