X-ray vision system
Thanks everyone for the suggestions. Mettler Toledo/Safeline definitely seems to be fairly well established in this space, and they have excellent support here. I use a lot of MT weighing equipment and they've been fantastic whenever I needed anything, so hopefully the same applies to their xray machines.
I spoke to my rep and asked him about the application and he immediately responded "oh yeah, we do that all the time. Easy!", so it sounds like a good option.
I've passed some contacts along to my friend and he's going to give them a try.
Thanks everyone. It's always great to have an automation hive-mind to consult with questions like this!
I did my apprenticeship in the dairy industry.
A small one with no budget for X-ray etc.
The feet (plastic) of the mixing arms on the cooling tables would sometimes un-thread themselves from the mixing arm and end up vacuumed into the towers and inside a 20KG block of cheese.
The solution was to drill and tap a stainless grub screw into the core of the feet.
Might not be relevant for a 20K recall, but I know you guys down under like to do things on a big scale :)
Hi, I'm having an issue in crimson 3.0 when I create a programme using a case statement referencing a fault word that each bit needs to change the...
257
I am trying to copy an array of real numbers into a UDT with a real data type element. I have attached a snip below showing my COP instruction...
204
I have an array of 55 REAL values. Is there a way to multiply based on the array location ? I have 55 transfer belts that are equally spaced...
156
Hello everyone, I'm working on a project that involves controlling an array of nozzles within a CNC environment, where the nozzles travel along a...
187
Hi. I'm using a Modbus ProSoft where I basically map data to a big INT array. Example, where GX_I_63HPU is a REAL, MNETC.DATA.WriteData[200] an...
21
437
