Y/Z Integrated Motorized Positioning Stage
dmargineau
Dec 2011
Midwest
2,507
Ready to give up and build something in-house...🔨
Been googling for a couple of days now and the only positive return was some Austrian outfit which seems to be happy operating strictly within the EU...:cry:
http://www.kml.at/downloads/KML_LMSM-D_EN.pdf
That's pretty much what I need!
A two axii (Y and Z) compact, motorized positoning stage with feedback which would carry a 10 lbs ( > $40K ) instrumentation device which needs to travel less than 200mm on each axis; the stage will position at intervals greater than several hours, will be located within an industrial environment and will be integrated on a A-B Logix platform.
Maybe the community will be able to assist a colleague in dire needs for a solution...Is it possible to find something like this available within North America?...🤞🏻
The actuators are the simple part you could use pneumatic hydraulic screw and the list goes on.
The big question I have is what is your tolerance on positiioning. The sensors are the challenge here.
Need more info on your tolerances and how fast you need it to move to new position.
Dan Bentler
Dan,
The movement tolerances are quite generous; +/- 1mm will do.
A travel velocity higher than 10 mm/s would suffice.
The stage will reposition +/- 200mmm at days' intervals and it has at least an hour to do so.
I'd rather have an electrical drive mechanism since the available pneumatic and hydraulic systems pressures/flows vary some +/- 20%.
We built something like this for testing using a garage door opener. Worked very well for our needs - did 17,000 cycles.
I think take a look at electric driven linear actuators if you are looking for off the shelf solution for the actuator.
Sensing position will still be the big challenge do not forget to allow for contamination of sensors and cutting the wires and a thousand other "how can I screw this up" considerations.
Dan Bentler
Probably we could build something similar; servo motors stage with position feedback on EtherNet/IP Logix Motion commanded Kinetix 6500 drives as we have done in the past...
It's the time we'll have to spend with the development what prompted me to look for something already built...📚
How do I get the mV or weight readings for individual load cells connected to summing board into the PLC? Do I use a MSG instruction and what are...
657
Hi all, I have an IDC from Rockwell, and it is super old, but new (had it in the spares). The previous one has gone faulty, and I need to set...
1,486
Hello I have a question about integrating an offline project for testing(PLC with same IP address as online), same type PLC and some exact tags...
2,267
I have an application with just one servo positioning axis on a jackscrew, and there is very little room for an electrical enclosure. In...
1,087
Hello. At workplace every person has its own personal card (HID iclass GL type). Now we want to access machine operations only to valid users i.e...
2,038
