Hi gang,
I am trying to locate the parameter(s) I would need to adjust an SDC25 set up as an on/off high temp alarm; that is paired up with another SDC25 set up as a PID temp controller. It seems that when the tank temp reaches the designated upper range limit the heating elements cut off and stay off. The original intent was to have the elements turn off at the upper limit but fire up when the tank reached the designated lower limit. This is an event/parameter/setup scenario. Any ideas?
Thanks,
JJA
Thanks,
JJA
