Yaskawa MotionWorks IEC Question
JerryH
Mar 2009
Tellico Plains,TN
110
I'm self teaching myself Yaskawa's IEC MotionWorks to make some changes to an existing machine we have. The original programming was done by an outside contractor which we no longer have contact with. It's going OK, figuring the most of it out so far but I've run into something I just can't get a handle on. In each POU he creates a Bool variable called "gEno" and uses it in many places. Take a look at the "gEno Example" and help me understand the purpose of this programming practice.
Thanks,
Jerry
Not an expert..but...it looks like it is a global variable that allows the next step to continue with the successful completion of each function block (ENO...enable out). Easier to keep using the same variable than creating a new one for each function block. Similar in concept to an array pointer that can be used in many loops.
Someone else with much more experience in Yaskawa MPiec controllers can correct me if needed. :)
I think I know what he is trying to do, but not sure. Function blocks that use EN/ENO only get evaluated if EN is TRUE. Otherwise, the output is retained. What he is doing would make sense if you used different variables for each one and the EN/ENO was actually doing something here. With the first EN connected to the left power rail, ENO will always be TRUE.
Can anyone confirm if the following capabilities exist for Yaskawa MotionWorks IEC / MPiec controllers: - Indirect addressing of variables -...
6,861
I am very new to PLC programming and would like to if there is a way to modify an existing MotionWorks program that uses block diagrams, by...
1,867
Hi all, I converted a project from MW+ Express to MW+ Pro, for the benefit of more percise control over the performance of different parts in...
1,887
I have a spin welding machine utilizing a Yaskawa Sigma II motor, with an MP940 controller. I am attempting to change the weld characteristics...
33
9,718
Dear forum members, By reffering to the blue labelled command on the attached file, Could you tell me what PLC register that is being limited by...
71
