Yaskawa MP2300Siec Camming
cstech
May 2011
TN
34
I have two parallel linear axes that need to have a relative position with each other at all times. I thought that camming might be ideal, however, I have learned that the master can only move in a positive direction.
Would having a "virtual master" that runs from 0-360 work in this case? Then create two cam tables, one for each real axis?
Any guidance or advice would be appreciated - thanks!
You can do this with gearing. If you don't need to use a cam profile, I would stay away from those functions. The MC_GearIn function will gear the axes in at their current positions, so if you gear in with them offset, they will remain offset.
I'm trying to add a MURR I/O module to an existing MURR network. As you'd expect, the input/output sizes change when the new module comes online...
1,847
Hi, folks; I've got a small 2-axis pick & place robot that we're looking to make some changes to. It is controlled by a Yaskawa MP2300Siec with...
3,353
I have setup a CompactLogix PLC connected via ethernet to a machine network alongside a Yaskawa MP2300Siec. The IP addresses are in the same...
4,964
Hi, i'm new to Yaskawa MP2000 IEC controller. I have a PMC-U-MP23S08 here with program inside. I also have MotionWork IEC Pro 2 installed...
3,806
I've got a Yaskawa MP2300siec motion controller and the Motionworks Pro software but I can't seem to figure out how to upload the program out of...
11,676
