Yet another FactoryTalk SE server redundancy question
lftmx3
Feb 2014
corporate paradise
27
So, after adding a second PC, purchasing another server license and setting up to function as a redundant server for FTV SE, I think I've discovered an issue. The idea was that when the primary server PC is shut off or unplugged, the secondary would kick in and the client PCs would never notice. However, after testing, this does not happen, instead the clients go blank and the secondary server PC says it cannot see FT directory(obviously, because it's on the primary PC).
Am I going to need to put the FT Directory on another separate PC to get this to work the way I want? Many thanks.
That will mean if that new PC goes down or has a network issue the system is down. It has been a long time since I used FTV SE but can you put it on both redundant servers?
The last time I did a redundant SE server, we had the directory installed on a third Server that was used as an engineering station.
So never saw the issue you have. Maybe someone more knowledgeable will chime in.
Howdy, Summary Rank beginner here. I don't have anything more than [RSLogix Micro Starter Lite], so I am using that for it's editing...
23
4,864
What software are you using or would recommend for drawing interlock, control and sequence diagrams? A full blown CAD feels over the top to me...
3,234
Hey Folks. Once again. I have an issue with CCW on my laptop. This is getting old, really...... I like the software but... Seems like every time...
23
7,283
This may very well be my last question. I'm not on to system alarming. Each station has its own set of alarms. What I have done is provide a list...
2,402
Thanks for the help so far guys. I have my screens made, login setup, and now I'm looking at trends. I want to trend a tank temperature, and I do...
2,133
