Zelio Ethernet communications
nickarsow
Jul 2007
Smolian
Hello all,
Please help me to understand how 2 Zelio Ethermet extentions could communicate each other? Please give a FBD example if possible.
Best regards
Nick Arsow
I know its a late reply but the short answer is no they will not communicate with each other directly.
If you really want to get them talking you will need a hub and then a higher spec twedo plc to do networking stuff.
Also a bit late on this,I speak under correction,but you can use the Modbus coms module and communicate between only Zelios
Hi. I am, in fact, not an specialist in PLC's but, in my work we remotely access a gear 500 kilometers away and we have observed, after some...
2,539
I set up a Zelio relay for totalizing supply & return flows for a boiler fuel oil a while back. There's a MODBUS over Ethernet card on the...
8,341
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
144
Hello good people! Attached is a very simplified version of a Zelio program containing what I am trying to do but it carries the same problem as...
1,281
OK, I thought I saved a few bucks buying a "new-open box" cable and it's the old version and SE doesn't support it, no driver available. Anybody...
1,498
