Zelio Logic USB-to-COM Driver for Win7(seven) x64
Frelecing
Oct 2010
Uruguay
73
Hi:
I just wanted to make a contribution because I've seen a lot of posts in the web regarding this subject.
Here I attach the driver that works for the communication between a Zelio Logic and a Win7 x64 PC with the SR2USB01 cable.
Note that not even in the official Schneider website have support for this, and I spent a lot of time trying to make this works, and finally it did.
Enjoy!
Hi all,
I have a SR2B201BD zelio relay and cannot communicate through the SR2USB01 cable i have. i have downloaded the above fie but don't know what to do next? what do i need to do once i download it to make it work??
Thanks,
Derek
Hi all,
Thanks,
Derek
You have to unzip the file (winRar, winZip, 7z, etc...), install (double click dpinst.exe) and follow the steps.
Then, in ZelioSoft 2, go to Transfer, Communication Configuration, and select the COM port that says USB between (). Then click on test, if it's succesfull, then the setup is over.
Good Luck!
Hi again, and thanks for the help,
It still doesn't work,
I opened the dpinst.exe file and the "welcome to device driver installation wizard" screen appeared, i clicked "Next" and then the "Completing the device driver Installation wizard" screen appeared, It had three sections with three green ticks, they were, "Nokia pccsmcfd - device updates", "Nokia (WUDFRd) - Ready to use" and "Nokia Modem - Ready to use" i then clicked "finish", does this sound correct?
After this was complete i opened a new screen to create a program and went to transfer and then COMMUNICATION configuration but when trying to choose an com port there is still only COM 1, Does it matter what version of Zelio soft im running on?
Sorry for the questions, but im in the middle of a college project and this is causing me such problems,
Thanks again,
Hi. What OS are you running? Windows 7 or XP.
If you let me know I will try to help. I unzipped the file and installed on a Windows 7 machine and all works fine.
Cheers, Jas
hi jas, I'm running on windows 7, 64 bit,
I unziped it but still doesn't give me the option to choose the usb output,
Derek
Hi Derek.
Unzip to a folder on your computer somewhere, doesnt matter where.
plug in Zelio programming cable to a USB port
message will come up saying unable to load driver or something of this sort, I assume.
Go to control panel, device manager, other devices (USB to serial bridge)
open up the settings for this by double clicking
Click on driver tab, update driver
browse computer for driver software
navigate to folder where you stored the unzipped driver
click next and that should be it. driver will be installed.
Now, on device manager you will see full description of port number etc. under ports (COM & LPT).
Good Luck, Jas
Good afternoon colleagues, a pleasure to greet you. In this opportunity I require some help from you. I am trying to make a shift register in...
2,242
I have programmed a Zelio logic to monitor 3 inputs, and coresponding 3 outputs for controling of 3 pumps. How to pause/resume timers for pumps ...
4,397
Hi. I am, in fact, not an specialist in PLC's but, in my work we remotely access a gear 500 kilometers away and we have observed, after some...
2,548
Hi there, I have a Zelio SR2B121JD and am trying to work out in FBD how to pause a timer. If I start a timer for a 60 second countdown, how can I...
7,281
I have a zelio logic 2 smart relay on an alarm system. The relay is getting no inputs at all yet is showing the coil to be energised and the...
2,549
