Zelio Logic USB-to-COM Driver for Win7(seven) x64
This is great. How did people survive without the internet and being able to share info?
Thanks to Frelecing
l am also having problems. l have extracted the files to a temp folder, there r 5 files correct ? , if l double click on the dpinst.exe file l get a message , do you want the computer to make the following changes , l click on yes and stuff all happens, l then go to device managers find the usb serial cable in question then to update driver , then browse my computer, then browse the location of the driver files which in this case is the temp folder, l then click on next and immediately get unable to install usb-serial controller. why ??????. I am running window 7 64 bit on a mack that has a windows partition, someone please help !
First try unisntalling any driver you have asigned to the cable. Then go to the folder where you unzipped the files, and 2click on dpinst.exe. Follow instructions and it should be done. Check the last post from the 1st page of this thread (one by jasmiller) for more info. Good Luck!
yes l have tried all that, what is suppose to happen when u 2 click on the dpinst.exe file , as mentioned all l get is a message that says do u want the computer to make changes, when l click yes that is all that happens and l do not get any instructions re the driver program,, any more suggestions please,.
l forgot to mention a couple of times l got the message "you have to run the 64bit version of dpinst.exe on this machine".
maybe this is a clue to what maybe wrong.
Hi:
I just wanted to make a contribution because I've seen a lot of posts in the web regarding this subject.
Here I attach the driver that works for the communication between a Zelio Logic and a Win7 x64 PC with the SR2USB01 cable.
Note that not even in the official Schneider website have support for this, and I spent a lot of time trying to make this works, and finally it did.
Enjoy!
Two year later and your post is the only driver I could find that works. Many thanks, much appreciated. Schneider certainly are in no hurry to support the product.
Good afternoon colleagues, a pleasure to greet you. In this opportunity I require some help from you. I am trying to make a shift register in...
2,241
I have programmed a Zelio logic to monitor 3 inputs, and coresponding 3 outputs for controling of 3 pumps. How to pause/resume timers for pumps ...
4,396
Hi. I am, in fact, not an specialist in PLC's but, in my work we remotely access a gear 500 kilometers away and we have observed, after some...
2,548
Hi there, I have a Zelio SR2B121JD and am trying to work out in FBD how to pause a timer. If I start a timer for a 60 second countdown, how can I...
7,278
I have a zelio logic 2 smart relay on an alarm system. The relay is getting no inputs at all yet is showing the coil to be energised and the...
2,548
