Zelio programable controllers
Hi thanks, i have very litte experiance in programing of these units.
I have been using Zelio,s for years SR1 puerly for one job the original program was writen very kindly for me by one of schniders [/HIGHLIGHT]engineers i have used this ever since and managed over the years to modify it a little.
I have writen a program hopefully enclosed to control a Water pump in a Spa pool.#Basis of opperation is 3 float switches.
1= High level alarm. N/O
2= Mid level normal opperation N/C
3= low level stop pump.N/C
1= no problem
2=if water level drops turns on top up solenoid
3= solenoid top up remains on and pump stops until float closes again then say 5 min delay before pump starts again.
Its the Timers i have difficulty programing and understanding with the configuration.
Is it possible to put a time clock into the program to stop the pump say between 10PM and 6 AM
How do you control the Spa heater? It should not be allowed to run when the water level is low, or the heater element will get too hot and burn out. This is actually more critical than the stopping the pump at low level.
Zip and attach the program here in the thread with a short note on what you want done. We'll be glad to help you make the needed changes.
Yes you are correct about the heater, usualy we have a flow switch in our instalations as this is an upgrade to the existing plant there actualy has never been a flow switch fitted and they have puerly relied on the High limit and normal thermostats in the heater to stop heating crazy situation as pump can loose Prime i found out the other day.
Realy needs this heater interlocking into circuit.
Spa Program Simulator using LogixPro
Here is a complete Spa Simulator PLC program, using the LogixPro Batch Mix Simulator set-up. It has the fill pump, drain pump, heater, air blower, high level, low level, and mid level switches. Maybe it will give you some level-control ideas for your Zelio program. The ZIP file is the LogixPro RSL program.
  • SPA_SIMULATOR.pdf
  • SPA_SIMULATOR.ZIP
Thanks for some reason unknown to me i carnt open the Zip file though from the PDF images it looks interesting for what i need.
Rob
Thanks, for some reason unknown to me I can't open the Zip file...
The ZIP file is a LogixPro *.rsl type. You will only be able to open it if you have a copy of the LogixPro Simulator software program installed on your computer. You can download a free demo copy from TheLearningPit.com (about $35 US to use it longer than 15 days).
http://www.thelearningpit.com/lp/logixpro.html
Here is a screen shot of the LogixPro Spa Simulator running at mid-level.
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
144
Hello good people! Attached is a very simplified version of a Zelio program containing what I am trying to do but it carries the same problem as...
1,283
OK, I thought I saved a few bucks buying a "new-open box" cable and it's the old version and SE doesn't support it, no driver available. Anybody...
1,500
Good afternoon colleagues, a pleasure to greet you. In this opportunity I require some help from you. I am trying to make a shift register in...
2,227
I have a zelio relay model sr2b121fu, the daily programer function block does not change when the time is right. I am trying to program this in...
2,035
