Zelio SR1 Software "Not Responding"
John P
Sep 2005
Idaho
I Have a Zelio SR1 24vac unit V1.7. The Zelio program is a V1.5. I am unable to program in free mode without the program "Not Responding". Am I doing something wrong? I looked all over on line; can I get the V1.7 some where? Should I get a Real PLC?
Hi, Did you ever get this resolved? If so what did you do? I seem to have the same/similar situation.
I lost my original zelip lader logic program for my zelio SR1 from my notebook and I had to upload from the device to restore it. Now I can't seem to edit in free mode as the Zelio Soft locks up Not Reponding.
The only resolution I can see is printing out the configuration and entering it all back in again under a new project, but I'm not looking forward to doing that unless I can help it.
Murray.
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
144
Hello good people! Attached is a very simplified version of a Zelio program containing what I am trying to do but it carries the same problem as...
1,281
OK, I thought I saved a few bucks buying a "new-open box" cable and it's the old version and SE doesn't support it, no driver available. Anybody...
1,500
Good afternoon colleagues, a pleasure to greet you. In this opportunity I require some help from you. I am trying to make a shift register in...
2,227
I have a zelio relay model sr2b121fu, the daily programer function block does not change when the time is right. I am trying to program this in...
2,035
