Is there any one can tell me what " T4:0/6 " means
This is copied from the online help, it's for a TON
Use the TON instruction to turn an output on or off after the timer has been on for a preset time interval. This output instruction begins timing (at either one second or one hundredth of a second intervals) when its rung goes "true." It waits the specified amount of time (as set in the PRESET), keeps track of the accumulated intervals which have occurred (ACCUM), and sets the DN (done) bit when the ACCUM (accumulated) time equals the PRESET time.
As long as rung conditions remain true, the timer adjusts its accumulated value (ACC) each evaluation until it reaches the preset value (PRE). The accumulated value is reset when rung conditions go false, regardless of whether the timer has timed out.
Instruction bits: 13 = DN (done)
14 = TT (timer timing bit)
15 = EN (enable bit)
If power is lost while a TON is timing but has not reached its preset value, the EN, and TT bits remain set , and the accumulated value (ACCUM) remains the same. This is also true if the processor changes from the REM Run or REM Test mode to the REM Program mode.
If either the Accumulator or the Preset is negative when the TON instruction is executed on a true rung, a Major Fault (0034) is generated.
Note If the rung goes "false" (loses logical continuity) during the timing process, the accumulated value is reset, and the DN, EN, and TT bits all reset whether or not the timer has reached the PRESET value.
Warning! Timing could be inaccurate if JMP, LBL, JSR, or SBR instructions skip over the rung containing a timer instruction while the timer is timing.
Addressing Help
Enter a TIMER address, TIME BASE, PRESET value, and ACCUM (accumulated) value. Timer files use three words per element, one for instruction bits (the control word), one for the preset, and one for the accumulator.
T4:1 represents timer file number 4, element number 1.
Rockwell Software 2000
