plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old July 28th, 2021, 07:28 PM   #16
JaxGTO
United States
JaxGTO is offline
Call me simple minded but what wrong with:
XIC bit 3 OTE bit0
XIC bit 4 OTE bit1
XIC bit 12 OTE bit9
__________________
I have to use Rockwell Software!
Old July 28th, 2021, 07:50 PM   #17
TheWaterboy
United States
TheWaterboy is offline
TheWaterboy's Avatar
Jax.... That would be the simplest... LOL. And not a bad idea.
Old July 28th, 2021, 09:02 PM   #18
drbitboy
United States
drbitboy is online now
drbitboy's Avatar
Same idea, general purpose:
__________________
i) Take care of the bits, and the bytes will take care of themselves.
ii) There is no software problem that cannot be solved with another layer of indirection.
Old July 28th, 2021, 10:36 PM   #19
koyeap
Malaysia
koyeap is offline
a dummy way to do this is create an AOI with 10 boolean input, and 1 int output:
in the AOI,
1) convert all 10 bool input to int using mov function (bool to int)
2) after conversion, bit 0 mul by 1, bit 1 mul by 2, bit 2 mul by 4......bit 9 mul by 512
3) sum all the result together and pass to int output
you can then map your bit 0-1, or bit 3-12 on the AOI, example if the AOI input bit0 and 1 both on, 1x1 + 1x2 you will get int value of 3, lets say if AOI all input is on, you will get 1x1 + 1x2 + 1x4 +......1x512 = 1024
Hope this help
Old July 28th, 2021, 10:47 PM   #20
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
There are no AOIs in a 1400, but you could shoehorn in something similar to one and make it nice and ugly and confusing.
I would do the brute force method JaxGTO described, but I am a brute force kind of guy. No need to get cute just for sake of "elegance".
Just use a BFH, and nail the bits where you want them, one by one with much greater efficiency that anything with a loop.
__________________
You've been taken, but you don't know it yet.
Old July 29th, 2021, 12:02 AM   #21
drbitboy
United States
drbitboy's Avatar
Quote:
Even that loop approach was fuglier than I'd hoped for, and on top of that in a 1400 each "caller" would need to move things in and out of the N255 file "arguments," etc.
So yah, I agree, no point trying to put lipstick on the pig.
That said, for bit ranges that don't touch the sign bit e.g. ten bits 3-12:
AND srcint 8184 dstint
DIV dstint 8 dstint
Cleaner than brute force XIC/OTE; possibly faster per scan but not enough to matter (lose ~1.5μs on instructions; gain maybe 4-8μs for fewer rungs).
__________________
Old July 29th, 2021, 06:07 AM   #22
parky
United Kingdom
parky is offline
parky's Avatar
Here is a simple one, just and & shift.
Note: the way this works with the shift is it works on the same variable so the AND function for the bits 3-12 the result is shown as the result of the shift it's just the way it works, rather than shift & store it into another variable it works on the source variable.
Rung 1 just masks bits 0-1
Rung 2 masks the bits 3-12
Rung 3 shifts the 3-12 to 0-9
Old July 29th, 2021, 01:36 PM   #23
TheWaterboy
United States
Mapped them using XIC OTE and that works fine. Thanks for the help guys.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Alternating Messages donl517 LIVE PLC Questions And Answers 8 February 28th, 2012 08:45 AM
Setting up a Program with PID parameters and Analog Signals BHazen LIVE PLC Questions And Answers 4 December 29th, 2011 05:44 PM
turning off a pid loop jimbom LIVE PLC Questions And Answers 11 December 6th, 2009 03:42 PM
Trying to split Double Word in S7 uptown47 LIVE PLC Questions And Answers 11 May 14th, 2008 04:29 PM
Splitting Integers into 2 bytes (decimal to Hex?) Altair LIVE PLC Questions And Answers 8 February 26th, 2003 12:31 PM
