Drew Ethridge
I have a network with 17 1734-AENTs. One AENT losses communication regularly.
The symptoms are
AENT
Module Status - Green
Network Activity - Rapidly flashing green
Network Status - Flashing red
Point Bus Status - Flashing red
IO
Network Status - Flashing Red
I have exhausted all my normal fixes without correcting the problem.
Replaced the ethernet cable to the first switch.
Set the RPI to 250ms (it is a VERY slow system)
Cable is run in a dedicated conduit and not near any AC.
Replaced the module.
Swapped a "good" module that has never failed with the "bad" one that fails. Now the "bad" one works fine in its new location and the "good" one is failing.
I do not believe it is an IP conflict because whenever the node goes down I cannot ping it.
Cycling power on the AENT always fixes the problem.
Does anyone have any other ideas on things to check before I connect with Wireshark?
Also, are there any recommended videos or blogs that help explain what to look for in Wireshark when trouble-shooting an AB network? I am a novice when it comes to Wireshark.
The symptoms are
AENT
IO
