geniusintraining
I know very little about drives in general, but I program and install them all the time, I need to know more, I don’t like swapping parts (not a good trait on my resume)
I had a AC drive that was turning the motor but not very well, it would stall after about few seconds under a load and run very good with little load, I check the normal stuff, but nothing really showed its little head.
I tried to change the drive but the only spare I had showed a power supply fault after the install, so I changed it back…so before finding another drive I wanted to be sure it was the drive I stared to check everything else, bearings, gear box, voltage, etc
The drive had power, but because this was a inverter (I thought) that it was hard to read the output voltage, I had 460, but was unsure if that was a good number, because of what I was taught, was I taught wrong?
I ended up swapping the drive for another one in the same cabinet, down loaded the parameters and it ran fine, the failing drive ran good under the new conditions (less load)
Is ‘power’, a direct relation to voltage? How can I read the power?
Or am I just really ****up on this?, I tried reading up on drives but there is not much info avaliable on ‘trouble shooting’
