rslogix500 to excel
randyk
Jul 2008
Florida
58
I'm trying to load RSLogix500 data(I/O, bits, timers, etc.)into excel, don't seem to be using the right keywords though(excel, edit, rslogix500) on the search for info. I have never tried to do this so any info would be appreciated.
Thanks, Randy
Thanks guys, have'nt had a chance to look at this another project of more importance came up, will let you know what I come up with.
Are you trying to read values from PLC memory into Excel?
Or are you trying to import register values from an offline .RSS file into Excel?
There is no easy way to do it (by easy I mean a few mouse clicks), but there is a way. Its more tedious than difficult. Export the program to a library file. File->Save As -> File Type .SLC. Now open the .SLC file using notepad or word pad. You will be able to see all of the data files and their values. You can then edit/cut/paste to make a .CSV file that you can open in Excel.
I am working on a small project which aims to calculate the number of starts and failing a series of motors and for this I wrote the program that...
1,305
53
So here's my situation, I have been tasked with modifying the logic to mimic a button press in the PLC. I have two identical machines however one...
543
Hello, I'm new to programming. I'm using RSLogix500 to modify an existing program for a SLC500. My plan was to use one of the existing inputs...
26
1,998
So i have an allen bradley rack (2080-LC50-24QWB), i have it connected through ethernet. I dont have an offline program so im trying to upload...
685
