RSview: massive tag substitution
tsaii
Aug 2011
Earth
I work with RSview32 for the first time.
I have to replace more than 200 tag names in a graphics display.
The Tag Substitution function is very tiresome for so many tags.
Is there another way to replace more easily a big amount of varialbes?
How are the tags named?
Example
North_Pump1_Start
North_Pump1_Stop
North_Pump1_Fault
And you need them to be South_Pump1_Something you could replace just the North with South by selecting all and put North in the search and South in the replace.
South_Pump1_Start
South_Pump1_Stop
South_Pump1_Fault
Do a Save as on the screen to a different name in-case the replace doesn't go right.
Hope this helps and makes sense and welcome.
Thanks a lot Bob O, I didn't know it was possible to replace only a part of the tag name (I don't know why I didn't try)
Your answer was very helpfull. (y)
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
327
Hello, I have converted RSView 32 to FTView SE 14 (I have tested FTView 12 before as well and there were some difficulties so I moved on to...
270
Okay, something I have not seen before.. RSView SE. I am working on an existing project. There is a value the customer wants trended and it is...
819
I have a request to integrate a pause button in RSlogix to be able to start/stop a video. Video format is not defined at the moment, so it could...
800
Hello everyone, I am having a problem with conversion from RSView32 to FT View SE Local project on version 12.00 (CPR 9 SR 12). Firstly, I have...
1,417
