06-06-06 PCMCIA card problem
bioplc
Jul 2005
tampa
97
Morning Everybody,
i am trying to install PCMCIA card drivers for DHplus interface for SLC 5/04 on my laptop...but due to some unknown reason my laptop is rebooting...
1) the floppies i have receieved along with the card do not have drivers for XP...so i have downloaded from AB.com/support. its an .sys extension file..do not know how to open it.
2) i have also received PCMIK utilities software floppy along with the card. it has dos based test tool to test the card...when i ran the test, it failed. Do not know why..
can anybody help me in installing the drivers
Thanks in advance
If the card you are using is the 1784-PCMK, then lookup tech note 2142258 in the Rockwell Knowledge base and follow the instructions. The Win 2000 & XP drivers are with the tech note.
To add the pcmk to rslinx
Make sure the pcmk card is in the laptop, open rslinx
click communications > configure drivers > add new
( I think from memory if you havent installed the pcmk drivers then when adding the card to linx it will install them and ask where the drivers are )
Hi. Looks like my CP5512 is broken. How can check if CP5512 is damaged or not? MORE INFO: My CP5512 doesn't work (Step 5.4 SP1). Cable (RS232 -...
3,702
I'm working on a project and have found myself in a situation where I need to use a PCMCIA card (I think a TSX SCP 114) to read modbus registers...
1,776
Good Afternoon , Dumb question..... I have a Windows XP Laptop and a PCMCIA slot that I believe is active. I have an adaptor with a small...
1,851
This happened yesterday. I plugged into an AB PanelView 600 using DH-485 cable through a PCMCIA card in order to back up the HMI file. I could...
3,632
dear everybody I have a PCMCIA card. and it's has programs all to run a machine, the data all, on it was created for B & R PLC (programmable...
2,199
