1200 plc Motion control with BIAS option
adam_lhadi
Feb 2022
algeria
59
Hi everyone
i have a delta VFD ,it's control signal is from 0..10V or in Mamps (no -10..10v)
my plc is 1251dc/dc/rly with analog output 0..20ma , i have used a 500ohm resistor to get the 10V
in order to use the motion control is it a must to have a VFD of -10..10V analog input and a plc of the same voltage rang -10..10V
in the vfd there is something called BIAS which give a result of (0 to 5V CW 5 to10 CCW)
can i use this feature instead of -10..10V
kind regards
Your problem is going to be that your Delta vfd needs to go forward and reverse with negative to positive reference.
Looks like Delta needs a digital input (MI number)
I assume your doing position control, not just speed control?
yes my analog output is only 0..10V
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
236
68
HI i would like to know how to get a variable that will store the amount of times a program has been executed. The issue is I have 3 DBs for 1 FB...
127
Hi. I’m trying to upload program from existing PLC S7-1200. Create new project in TIA v15.1 then upload. After upload successfully, go online but...
281
Hi Guys, I am trying to establish communication over profinet between Siemens S7-1200 PLC as IO device and codesys plc as IO controller. But I am...
43
3,140
