1336F to Powerflex 700 on controlnet, PLC/5
Jasondelane
Mar 2015
Florence sc
221
Yesterday we had a 1336F pop and we don't have one in stock. We've got another one coming but in the meantime we're exploring the option of replacing it with a Powerflex 700.
I've put 20-Comm-c adapter on the powerflex and changed the node to the same as the old 1336F, and I can communicate with it via RSLinx, Drive Explorer, and RSNetworx. I've had no problem setting it up on RSNetworx, but for the life of me can't get the PLC to issue it a start or stop command using the same logic.
Looking through the program online, it seems that the PLC is not receiving a "drive enabled" status bit to allow it to send a start command.
Another thing is that when I go into the IO configuration on RSLogix 5, it's still showing a 1336 instead of a Powerflex after I've downloaded everything from RSNetworx and done a download from the PLC using the new Controlnet file.
I think I'm missing a step somewhere? Has anyone ever done this type of conversion?
Hi all, I am working with an Allen Bradley 1336 Plus ii drive on an air compressor. We added a new pressure controller with a 4-20ma output and is...
1,738
hi, I have the 1336f-L4 ac drive and somehow I cannot change/adjust value in program. The input mode alway in status even I plugin the TB3 module...
1,348
Hello, I had to change old 1336F-brf20-ae-en to new same one. I recorded all parameters and put then into new drive. DeviceNet is not working...
1,194
All, I have a PowerFlex 525 driving an agitator motor. The goal is to have the agitator start automatically after a power loss or a comm loss. I...
63
I've got a Powerflex 700 that doesn't like to get going in the mornings. This motor will run anywhere from 30 seconds to 5 minutes before it just...
173
