1747-SDN trouble
kolyur
Oct 2004
Wooster, Ohio
1,602
We have a piece of machinery with an SLC500 and 1747-SDN module. This morning the PLC faulted due to a problem with the SDN module. When we cycle the power the LED display on the SDN reads 88 (LED test?) but just hangs there and doesn't change. The other weird thing is that the module power and network status LEDs are both off. It's getting backplane power and we checked that the trunkline power at the module is indeed 24vdc. So how could the power LED be off? I'm suspecting that the SDN module is bad but I don't have much experience with Devicenet so if someone could shed some light on this I'd appreciate it!
If the 1747-SDN display shows only "88", then it's stuck in self-test mode. I suspect this is a nonrepairable failure and you need to replace the module.
webbyjules said:
I hope you have the scanner programme backed up or you may be in trouble !!
Fortunately we were able to order it from the OEM and they are going to pre-program it for us. They're charging us about 15% over list price which is well worth it in my mind since we have no way to program it here.
We are in the process of upgrading a controls system. The existing system is a SLC500 with some IO cards and a 1747-SDN module communicating to a...
560
One of our running machine's DeviceNet Module (1747-SDN) had malfunctioned. So, we replaced it with a new one from spares. We maintained the...
3,074
I have a 1398-DDM-009X-DN that was talking to a 1747-SDN in a rack with a SLC 5/05. Recently, after a download of new parameters to the servo...
3,131
Good Morning , After all these years , I still can't wrap my head around DeviceNet :( . I have RS Networx / DeviceNet. I would like to...
18
5,171
Morning fellas, Anyone know if it's possible to receive the error codes displayed on 1747-SDN modules in a SLC 5/05 PLC? I've looked through the...
1,616
