1747-UIC and c13 cable for SLC500(Fixed)
saroj
Guest
S
I would like to communicate to a Fixed i/0 SLC-500 using the 1747-UIC.
Is it AB 1747-c13 cable is the only correct choice ? ( i.e RJ45 connection on both side). Will the normal computer network cable with
RJ45 will work ?
The other port on 1747-UIC is the 9 pin RS232 .Is it also possible to
use this port for connecting to the Fixed I/O slc-500 and using the same DF1_RS232 driver .Request reply help.
Regards.
Saroj.
saroj said:
The other port on 1747-UIC is the 9 pin RS232 .Is it also possible to use this port for connecting to the Fixed I/O slc-500 and using the same DF1_RS232 driver
Both ports on the UIC are DH485. You will not be able to connect via DF1 with this device.
se me desprendieron los cables del cable usb quiero soldarlos pero no se como van los cables si alquien me pudiera proporcionar una foto o como...
410
Hi again, so this new client has a SLC 5/02 with a DH485 port. I have the older white 1747-UIC adaptor, which I have only ever used for the RS232...
1,302
Hi Everybody! Has anybody ever tried using the 1747-UIC (USB to DH-485) converter as a straight USB to RS-485 converter? Since it present to the...
2,444
Hello I will make it short and sweet. I need the cable that goes from the slc 501 to the 1747-UIC RJ-45 connection. From what I can find it...
1,258
Hey all, first time posting. I have gotten a lot of great info from all of you in the past. I have searched the forums and google as much as...
3,484
