1756-HSC/B " I.Totalizer" Tag Does Not Generate?
Olly1441
Aug 2013
Idaho
It's my first time using the 1756-HSC module and when I add the device to the local rack in my I/O tree, the following input tags are generated:
Local:7:I.CommStatus
Local:7:I.CSTTimestamp
Local:7:I.IsOverridden
Local:7:I.NewDataFlag
Local:7:I.OutputState
Local:7:I.PresentValue
Local:7:I.StoredValue
Local:7:I.WasPreset
Local:7:I.WasReset
Local:7:I.ZState
The Totalizer tag which is mentioned in the manual and in other posts about this device is missing. I need this tag. I have installed the 1756-HSC/B EDS file from the Rockwell website. I am using RSLogix 5000 version 20.14
Any ideas?
Welcome to the forum Ollie1441 - When you add the module to the I/O Configuration, choose the HSC Data Extended option for the Comm Format
I am using an HSC/B card to measure a speed wheel with a powered bidirectional pickup. I am using Encoder X4 mode and using the Totalizer tag to...
1,955
I have am trying to determine if I can use a 1756-IB16I (or some dc input equivalent) to handle a 24vdc input pulse frequency of 80 pulses per...
962
Just finished an upgrade from a SLC500 to CLX where they had a 1746-HSCE and we're now using a 1756-HSC. Two wire pulse signal from the...
1,313
I have an older SLC500 that has a PLS card in its rack. I want to remove the SLC and add a L23E-QBFC1. Can a resolver be wired up to the High...
1,699
Our ABB Vision System requires a Pulse Train Input from an Encoder (12-15 VDC)to calculate the speed of the web. Instead of adding an encoder to...
1,576
