1756-HSC with open collector output encoder
pauly
May 2002
South Wales,U.k
244
I have a Red Lion model ZMD encoder which I would like to interface to a 1756-HSC card in a Logix rack. The input connection details are a little confusing however. One of the articles on the Rockwell knowledge base talks about using a pull up resistor the other shows the open collector output connected directly to the card please see attachments. Has any body had any experience with this card and could point me in the right direction?
Thanks in advance.
  • Encoder pullup resistor.doc
Both ways are OK for 1756-HSC.
Connection without pull-up resistors can be used with cards that have isolated return wires per each channel.
I have am trying to determine if I can use a 1756-IB16I (or some dc input equivalent) to handle a 24vdc input pulse frequency of 80 pulses per...
938
Just finished an upgrade from a SLC500 to CLX where they had a 1746-HSCE and we're now using a 1756-HSC. Two wire pulse signal from the...
1,304
I have an older SLC500 that has a PLS card in its rack. I want to remove the SLC and add a L23E-QBFC1. Can a resolver be wired up to the High...
1,691
Our ABB Vision System requires a Pulse Train Input from an Encoder (12-15 VDC)to calculate the speed of the web. Instead of adding an encoder to...
1,573
I am upgrading HSC modules and have some questions. I can't attach the manuals for reference as they are too large. 1746-HSCE uses M0:e.1/4 for a...
1,655
