1756-IB16 and 1756 OB16E
Nov 2009
India
116
Hi
I am using 1756 IB16 and 1756 OB16E modules, when i configure these modules, i can see 32 bit data tags instead of 16.
Pls let me know i need to use the bits form 0 to 15 for 16 channel is it?
Use bit's 0-15 for the data, "Local:4:I.Data.00 - Local:4:I.Data.15" Same for the Output.
32 bits is the native size for the ControlLogix, so it is much more common to see modules use at least 32 bits (but there are actually more... The output module for example, has a 32bit output area, and a 32 bit input area which reflects the output status, and another 32 bit input area which reflects the channel fault status (for the OB16E). There are more 32 bit words in the configuration data as well.
I have moved theses around my work bench long enough. If anyone wants to cover shipping, he/she can have them. First dibs wins.
1,557
Every now and then, you get asked a question that humbles you and makes you realize just how much more you've got to learn! I was just asked one...
3,680
Hi all I have a ControlLogix 1756-L71SP that i want to use for general PLC applications, not safety. I am running Studio5000 v33, i can't...
62
359
Hi, I have two quick questions: 1- Could I use 1756-IA16/A with TTL inputs? Sourcing (PNP)? Sinking (NPN)? Either one? 2- What does /A in the part...
158
