1756-IF6CIS/A Add on profiles
bdauliya
Supporting Member
Sep 2020
New York
36
Hello all,
I am trying to download a Rslogix program to 1756-L61 ControlLogix5561 Controller. Rev 16.21.
while downloading, I get this error " Module profile could not be loaded. The Profile may not be installed, or there is no profile support for the modules revision". The module is Analog input 1756-IF6CIS/A.
I tried to to download Add on profiles for this module from Rockwell's website but for some reason it gets timed out when i try to download.
is there any way I would be able to download my program without AOP or any work around?
Thanks in Advance!
Hello all,
Thanks in Advance!
Here is a solution posted for V20. It's worth a try.
I looked for the IF6CIS specifically but could not find an xml file for it :(
Solution
To re-add the module into old Module Directory:
Open Command Prompt as Administrator
Type the following commands, one by one:
cd "C:\Program Files (x86)\Rockwell Software\Studio 5000\Logix Designer\ENU\v27\Bin\
Note: you can replace v27 with any other version.
mdinstall.exe +a 1756Analog.xml
Restart RSLogix 5000, try to add that module.
Thanks for your suggestion.
I was able to download AOP for that module from Rockwell's website. That worked!
We are currently upgrading our PLC5's to Controllogix 1756-L73 The 1771-NIS modules were using with the 1771-RTP4 terminal block for connecting...
2,199
Hi, I'm new to controllogix but 20 years with PLC5. I am converting a PLC-5 program to controlligic. I had PLC 5 NIS analog input modules, and in...
2,167
Hi all I have a ControlLogix 1756-L71SP that i want to use for general PLC applications, not safety. I am running Studio5000 v33, i can't...
84
404
Hi, I have two quick questions: 1- Could I use 1756-IA16/A with TTL inputs? Sourcing (PNP)? Sinking (NPN)? Either one? 2- What does /A in the part...
183
