1756 L81 v.30.00 ESM module fault disappeared
bigLee
Jun 2018
Florida
77
Hello,
I had an out of box controller 1756 L81 Contrologix. Was running for about a week and started getting the ESM fault. Powercycling did nothing. I downloaded the program again to flash and the ESM error went away. Maybe 2 days later it reappeared. Downloading to the controller would clear it temporarily.
This particular unit doesn't have a removable module. You have to replace the whole controller.
I have since put a blank program in the controller and left powered on for 2 weeks. The ESM fault has not occurred again.
Has anyone else experienced this? Is the battery good or should I just get a new controller?
Is the PLC in a temperature controlled environment?
I've had issues with the new series and faulting after being stored in a cold environment, when PLC came back to an OK temperature the fault cleared after a couple of power cycles.
Hello, Before i reach out to local supplier, figured I'd ask here regarding this issue. Right out of box, the controller had a solid red SD LED...
2,373
Hi all I have a ControlLogix 1756-L71SP that i want to use for general PLC applications, not safety. I am running Studio5000 v33, i can't...
79
386
Hi, I have two quick questions: 1- Could I use 1756-IA16/A with TTL inputs? Sourcing (PNP)? Sinking (NPN)? Either one? 2- What does /A in the part...
182
Hi all, installed on chassis A17 an A/I from Allen-Bradley , problem is what ever I do , all channels are sticked on value 39.9 and cannot change...
155
