1794 ID2 and SMC Stroke Readind Cylinder
lexarius
Jun 2006
Toronto
I've got some problem trying to get any readings from SMC stroke reading cylinder using 1794 ID2(Series B) module.
My configuration is SLC 5/04 - 1747 SN scanner - SMC EX500 Gateway unit (for remote I/O). I've used BTR and BTW instructions to control the module but I can not get any readings.
Hi Everyone, I need help with setting up 1794-ID2 Card with push-pull type encoder with A+ (Up counting) and B+ (Down Counting). The 1794-ID2 is...
1,561
Good Morning , I am going to be re-working 2 portable machines. I am going to have one main panel with a CompactLogix and 3 PowerFlex...
1,492
I am using an oval gear meter with a pulse rate of 2050p's /L. I am trying to figure out how to program a rate counter to track flow rate at...
2,642
I see no threads about the 1794 ID2 incremental encoder module. I have used Flex logix before but have not done Block transfers to any of the...
3,086
Just a few quick question, can you use a prox switch with a 1794-ID2? I need to read a prox to measure RPM, I'm having a major brain **** right...
2,484
