.200 files
Giles M
Jun 2009
UK
I uploaded a hardware config from a Siemens S7-315-DP processor recently using Step 7 V5.4 and noticed that some of the nodes on the profibus DP network use .200 files.. notably 3 older Pepperl-Fuchs encoders. Made some changes to another node on the network and saved / compiled and downloaded the hardware config to the processor. Now the online hardware config can see the encoder nodes on the network but does'nt know what they are. Am I correct in saying that I will need to find the old .200 file for these encoders? If I do magically locate it will I be able to use it in Step7 V5.4 hardware config or will I need another software package? This application was developed some years ago and we don't have access to the original code.
Thanks...
Giles
Where are you seeing the reference to the .200 files? In the early days of Profibus the Siemens configuration tool was COM ET200 which produced its config files with the extension .200 but as far a I can remember, it still used .gsd files for slave descriptions.
Nick
Just had a check. Type description files can have a .200 extension. Many are found in the directory: C:\Program Files\SIEMENS\STEP7\S7DATA\NSMET
Nick
Thanks Nick...
The reference to .200 file shows up when I right click on the node icon in the hardware config and select properties. For instance the encoder nodes all show GSD file (type file):pF5046AX.200
Siemens got back to me to say that .200 files are never used with Step7 which is a bit confusing as the hardware config shows the file above.
Perhaps I have to find an older .GSD file for these encoders other than the one located at Pepperl+Fuchs.
Cheers..
Hi I'm in the middle of upgrading (if you could call it that) from an old S5 IM308B profibus card to a not so old IM308C. I have the original...
2,702
So I'm working on writing my first PLC program, and I don't really understand the PLC memory / data files. I see the various things like Integer...
4,017
Could someone answer a pretty simple question for me. Can you have more than 1 ladder in the program files for a micrologix 1200 program? I...
3,260
4,192
Hello, I have a question about an encoder that has absolute measurement. Specifically, it's the Lika SMA5, which I would like to connect...
61
