2711_RP1 Rs232 question :)
jasil
Jun 2012
Building
48
I can make a DF-1 driver in linx and see the panelview, but when I open factorytalk and copy the running configuration on my laptop I don't get my DF-1 driver.
Do I have to manually add this? If so how?
If I want to download to the unit via rs232 I can't ever get a DF-1 path to show up in the transfer utility portion to do that.
I want to prove to myself I can do via rs232 because I run into this from time to time even though 95% of the equipment is Ethernet.
**My brain is too small I can only function with IP RS232 kills me everytime**
So you can get the DF-1 driver to see the panelview from your desktop and you want to do it from your laptop?
If that's the right question, there is a hamrony.rsh file that rslinx uses to store information like that. You can't copy it from your desktop to your laptop ... but you can export the file from your desktop to a file and import that on your laptop. It works maybe 10% of the time for me. I usually end up having them both open at the same time and configuring them the same way.
Or you can open your laptop and set up the df-1 driver on the usb-to-serial port manually. It will grab the first com port it finds, which is usually the mouse, or trackball, or touchpad. If you open your control panel on your laptop you should be able to find the USB to serial port number under PORTS ... depending on which version of windows you are using
If you have an ACTUAL serial port on your laptop, choose that one.
Hello, Friends Please someone help me find right cable to communicate Panelview 600 (2711-B6C9) to Micrologix 1200 (1762-L24AWAR). AND any advice.
281
Client has multiple spare Panelview 550 (2711-T5A10 L1 PV550 Touch Devicenet)...
703
I'm a beginner to PLC and Hmi programming. any one please help how to connect HMI to pc. HMI has a printer **** enabled by default, It does not...
432
need instruction on how to download an existing program to the PV. I am very new to PLC's they came with the job so now sink or swim don't want to...
928
Last night electricians replaced the panelview and now there is no comms between the panelview and the PLC. The processor is a 1747-L541 SLC 5/04...
909
