2711R and CompactL16ER
jcurado
Sep 2003
49
Hello
I'm having an hard time configurating the communication between a 2711R-T7TA HMI and a CompactLogix 1769-L16ER.
On CCW (V9), I chose Protocol: CompactLogix L1 and on address 192.XXX.XXX.XXX,1,0
Added the tags manualy with the same name as in the PLC but I always get the same error: Data Access Error for Alias XXXX, Controller PLC-1. Communication Flag is 0.
I think I tried everything. Could you please tell me what I'm doing wrong?
Thank you´
JCurado
Problem solved
Sorry for the time it took me to inform, but the internet access I had in the site did not allow me to reply to posts, only to start a new one (?).
I was abre to solve the problem, after trying almost everything. Made a new CCW program and it worked. I had to redo everyting, but it solve the problem. I wish I had done that earier...
Don't kown exacly what was the problem, but some of the tags started as program tags and later were changed to controller tags. Maybe the CCW program was pointing to the wrong place.
Thank you for trying to help.
Jcurado
I have an HMI 2711R - T4T Series B, and I want to know which PLCs, besides Micro 820, can communicate with it.
100
Good morning all, programming a Panelview 800, I have a maintained push button programmed on screen 1. I copied and pasted it to screen 2. Could...
1,168
Has anyone ever used a 2711R -T7T Panelview 800 with a Compact Logix PLC over Ethernet comms? the 2711R -T7T Panelview 800 is usually programmed...
3,951
Hi I have a problem described below: I have a panelview application which is actually running on a 2711R-T4T panelview 800 which I call the "old"...
3,548
Hi Guys, I have a little problem, i need install the archive eds for PanelView 800 (Code ref. 2711R-T7T), but i downloaded of page oficial...
3,262
