343-5 all leds flashing
Note your existing user parameters, and try the following adjustment:
Remedy:
- Use the bus profiles Universal, Standard or DP
- If you use user-defined bus parameters please observe the following limits:
- max. Tsdr + 17 <= Tslot_init <= 16383 t_bit
In other words, make your Tsdr value equal to or between 17 and 16383.
Yes... if there was an actual download link for the firmware... I think Siemens might have removed the link. I hunted for it to no avail.
You are right. That is odd indeed. And the support entry is from 2002, one should think that the latest firmware is always available for download. Maybe they found a problem in the firmware V4.1 and never got to fix it.
techno44, I would contact Siemens Support, and ask about FW4.1 (quote the support entry 10605201). The fixes in FW4.1 looks like they could be relevant to your problem.
Hi everyone, I want to upload the program from my CPU317TF-2 DP to my PC via connecting to CP 343-1 Advanced since it has LAN ports and the CPU...
184
Hi, I have a customer with a S7300 from around 2013 which they link to approx 25 inverters, 3 DP to DP converters and 5 IM153 remote I/O units...
334
Hi , Looking for some help. We have a 343-1 PN Lean Card & 315-2DP connected to an external system collecting data. After a recent shutdown...
71
I've been called to a site to assist with an ASi fault. The line has been down for a couple of weeks following a failure of the ASi power supply...
1,337
I have an S7-300 and an HMI. The HMI is the only device that talks over Profinet through the CP343-1 module. It's run fine for a couple of years...
517
