4-20 loop through NI8 card and DCS ???
karivelm
Nov 2006
Quebec
66
Hello,
I was wondering if it is possible to include a NI8 card in an existing 4-20 loop.
I have an existing 4-20 temperature reading going from a DCS (supplies the 24Vdc) to a temperature transmitter.
I would like to send out the same reading to a SLC/05 through a NI8 card is this possible.
I attached a drawing of the modified DCS loop going through the NI8 card.
If
- an NI8 card is single ended with a grounded signal (-) terminal, and/or
- the loop power supply (-) is grounded on either or both DCS or PLC systems
then the possibility of a ground loop exists.
So, yes it can be done, but there's the possibility of a ground loop.
I personally prefer to use a loop isolator, which eliminates the prospect of a ground loop.
Dan
With series loops, the total resistance must be considered. The 4-20ma output device will probably have a spec on maintaining 4-20ma upto a maximum loop resistance. All devices in series add to this resistance,
in the case of the NI8 it is 250 ohms
Hello, I am trying to make an Automatic Coolant Dispensing station for my client. This unit will be stationed next to a CNC Machine to monitor...
56
14,598
Hello again, SCL struggles continue but this time I'm trying to scan for 0 statuses in an array of boolean variables. Any ideas how to implement...
2,170
I hope I'm in the right forum for this... I'm trying to use a vb loop to dynamically change the .Caption, .Visible and .VerticalPosition...
1,887
Hi, I've got a little problem that involves arrays and looping it. I've got an FB and 3 arrays of 128 bools inside. One is a list of detected...
17
11,187
Hi, I'm quite new to Rockwell PLC and currently trying to implement the following if Sw1 then for i:=1 to 20 by 1 do xEnable := 1...
398
