4-20mA signal generator
ken c
Jul 2004
new jersey
anyone have a parts list to build a 4-20mA signal generator? I have a 24V dc power supply rated at 2.4 amps. this will be used for testing of a PLC (e.g. simulating signals). I'd like the ability to have multiple signals, individually adjustable.
4 to 20 ma signal
You're smart. I use 3 0r 5k ohm potentiometer(pot), 2 watt maybe. This is useful in making the PLC thinks that the transducer output is changing in values or reacting to what it is sensing.
The thing could also be used as voltage output as in many sensors that can output either ma or volts.
Re: 4 to 20 ma signal
BOB F said:
You're smart.
Well Tom
You are finally getting the recognition you deserve
Paul
Hey folks, I have a situation where I need to connect a 4-20mA transmitter to an AI card that only does 0-20mA. On top of that it only has 8 bit...
2,440
So, gentlemen, I am going to ask if there is any set length that should be followed for a analog signal. We are installing a system for a plant...
3,664
I am trying to debug a pressure transmitter that outputs a 4-20 mA signal. Currently , the value is changing on the HMI screen and PLC depending...
2,353
Just asking for clarification here, but from my research all I need is a 500 ohm resistor across the AI and the common? Heres my schematic. I...
2,597
Any one know of way to split a 4-20 mA signal 4 ways? Do they even make such a device? Thanks
3,670
