4-20mA Signal Splitter
what about using 2 common modele instead of 1 rare to find?
I'm curious to know why you would need 5 output of the same signal? is it because their is no plc brain?
Hey folks, I have a situation where I need to connect a 4-20mA transmitter to an AI card that only does 0-20mA. On top of that it only has 8 bit...
2,433
So, gentlemen, I am going to ask if there is any set length that should be followed for a analog signal. We are installing a system for a plant...
3,654
I am trying to debug a pressure transmitter that outputs a 4-20 mA signal. Currently , the value is changing on the HMI screen and PLC depending...
2,345
Just asking for clarification here, but from my research all I need is a 500 ohm resistor across the AI and the common? Heres my schematic. I...
2,586
Any one know of way to split a 4-20 mA signal 4 ways? Do they even make such a device? Thanks
3,661
